Results 1 to 36 of 36
Thread: Psychometric exercise
Threaded View
19-12-2006, 07:06 AM #4
Re: Psychometric exercise
To quote my own post: let's say that we have an internal load of 50 kW (170607 BTU/h or 14.21 TR) from which is 20% latent heat.
In the room are 30 peoples and local regulations states that there has to be a fresh air intake of 15m³/h/person (8.8ft³/min/person)
The RH inside the room must be kept at 65% and temperature 22°C (71.6°F)
Outside conditions can go in winter from -10°C/50% (14°F) and in summer to 35°C/80% (95°F)
Bypass factor of coils are all 0.2
Calculate:
needed cooling battery,
heating battery,
is a supplementary preheating or after-heating necessary,
how much moisture will be removed in the worst condition,
the humidification must be done with water kept at 10°C, as second case with water which takes the same wet bulb temperature as the air passing by, with water kept at 50°C, with steam at 110°C (230°F)
how much supplementary energy will be needed in the most humid situation to reheat the air to the desired room condition,
I'm sure that this is a difficult exercise for many amongst us, especially because this isn't real refrigeration but belongs anyhow to the basics.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
