    Bernoulli's Avatar
    Bernoulli Guest
    Coil in Coil condensors and subcooling.
    I have a refrigeration plant fitted with coil in coil condensors. I have always found them to have excessive subcooling, in the region of 10-20 degrees C, even after I have just recharged the plant with the correct gas charge and it is running at the design HP. I have eliminated air in the system as a cause, so does anyone have any idea whether this is a quirk of this type of condensor, or is there amother possible cause? As an aside, I also have a small A/C plant that has the same condensors and also has siimilar degrees of subcooling. In both cases the condensors are fed with seawater and HP is controlled by way of Penn valves.
    Yours, hitting himself on the head with a hammer in order to make the thinking valve work, Bernoulli.
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    Re: Coil in Coil condensors and subcooling.
    What is a coil in coil?
    Aug 2005
    5,302
    I am assuming it is a coaxial condenser. Or, it could be a vented double wall condenser.
    Oct 2003
    5,630
    34
    The higher the SC, the better, so why worry.
    It's normal when the condensor is oversized or when there's a subcooling section in an aircooled coil last coils at the bottom going up again)
    Mar 2006
    Merate (LC) - Italy
    52
    2,549
    Here our disagreement remains.
    I have a typical example just a coupld of days ago. A two circuit chiller, 2x40 TR, air cooled with condensing fan speed regulation.
    HP pressure regulated at 16.5-17 bar, with ambient at 10°C. Liquid temperature around 28°C, SC at around 17/18°K.
    The performance of the chiller is well above nominal, thanks to high SC. Result = low pressure trip because of too high cooling capacity in the evaporator, TEV trying to cut the feeding.
    Oct 2003
    5,630
    34
    Did once a calculation for a normal SC (5K) and then a more excessive one (18K): cooling capacity increased with +/- 13%
    Plotting this out gave me an evaporating temperature drop from 1°C (chiller application I suppose) to -4°C (or +/- 5K).
    Is this enough to trip the cutout safety switch?
