Results 1 to 14 of 14
    Jan 2006
    Croatia
    68
    2,263
    31
    Question Help about British standard for screws
    Hi, all
    Please I need some help about screws.
    What means 2 B.A. x 3/4" LG Socket cap Tuflok coated screw
    Some link, drawing....
    Best regards, Josip
    Sep 2005
    Australia
    33
    Re: Help about British standard for screws
    http://www.engineerlive.com/european...uctivity.thtml ---- tuflok
    http://www.gewinde-normen.de/en/index.html ----- thread standards
    http://www.accuratescrew.com/info/SocketRef.htm
    In this last one under point 14 there is something about LG
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, Hiitsme
    Quote Originally Posted by hiitsme View Post
    Thanks for links, but for me the most important is 2 B.A. ... is that related to class, material, size, or...?
    Need also some info about W.S.I No. 27 Class 2 and W.S.I No. 136 related to tightening torque...
    Best regards, Josip
    Aug 2005
    5,302
    Hi Josip,
    http://en.wikipedia.org/wiki/Screw
    Quote Originally Posted by from above link
    British Association screw threads (BA)
    A later standard established in the United Kingdom was the BA system, named after the British Association for Advancement of Science. Screws were described as "2BA", "4BA" etc., the odd numbers being rarely used. While not related to ISO metric screws, the sizes were actually defined in metric terms, a 0BA thread having a 1 mm pitch. These are still the most common threads in some niche applications. Certain types of fine machinery, such as moving-coil meters, tend to have BA threads wherever they are manufactured.
    Here is another link that tells the whole story...
    http://en.wikipedia.org/wiki/British..._screw_threads
    It looks like the 2BA just tells you the the thread pitch and size.
    Hope that helps
    Sep 2003
    ISRAEL
    72
    4,248
    I didn't know that there is a European standard for screwing
    Chemi
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, US Iceman
    Hope that helps
    Thanks, yes it helps, but nothing about material, pity
    Hi, Chemi
    Quote Originally Posted by chemi-cool
    Chemi
    But now, you find out, some standards always exist
    Best regards, Josip
    Sep 2005
    Australia
    33
    Talking Re: Help about British standard for screws
    Chemi
    Here you are not able to find excuses to the miss...:-D
    Sep 2005
    Australia
    33
    Hi Josip,
    this 2BA thing....
    Doesn't it mean simply 2 pieces of screws which are BA standard????
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, Hiitsme
    Hi Josip,
    this 2BA thing....
    No , I need 8 pcs (in text is 4+4 2B.A.)
    Best regards, Josip
    Oct 2006
    Bucks, U.K.
    71
    604
    Hi Josip,
    B.A. stands for British Association thread form.
    They range in size from 0 BA (the largest) which is about the same size as a M6, to I think about a 19 BA which is extremely small. The normal sizes are the EVEN ones 0,2,4,6,8,10,12. They used to be used alot for electrical equipment....still come across them in UK, but metric taking over.
    2 BA is very similar to M5 and the 10-32 UNF. I think they will all thread in each other to a degree (some tight, some loose)
    The material is not dictated to by the BA....you can get them in Steel and also in Brass. Normally have slotted heads.
    The 3/4" LG would refer to the length (19mm). The Socket cap is the Head type which would be a recessed Hex (i.e Allen Key) probably with a knurled edge. I expect these to be Steel with a blackened oxide finish.
    Hope this helps. More info on google.
    Aug 2005
    5,302
    Quote Originally Posted by Electrocoolman
    Are these then considered to be heat treated for higher strength?
    Based on your description this sounds a lot like the tiny bolts used in safety heads on large recip compressors..
    Oct 2006
    Bucks, U.K.
    71
    604
    Hi US Iceman,
    Yes the black oxide finish screws are heat treated HT steel,.......but currently I cannot find any listed in a BA thread, but that does not mean that they aren't available.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, all
    Found this on the net
    Nothing about material but I believe any material we need we can use for.
    Best regards, Josip
    Attached Files Attached Files
    Scotland
    104
    Dear Josip,
    I think you got all the answers already - all I can add is that BA threads are not much used these days, except in modelmaking and other hobbies. They are pretty small - like the screws that hold the cover plate onto an electrical socket. The LG reference I think was just an abbreviation for "long" - for example 2BA x 6LG is a 2BA thread 6mm long. 2BA only tells you the screw diameter and thread form.
    cheers
    Andy P
