Results 1 to 14 of 14
11-12-2006, 06:48 PM #1
Help about British standard for screws
Hi, all
Please I need some help about screws.
What means 2 B.A. x 3/4" LG Socket cap Tuflok coated screw
Some link, drawing....
Best regards, Josip
11-12-2006, 06:58 PM #2
Re: Help about British standard for screws
http://www.engineerlive.com/european...uctivity.thtml ---- tuflok
http://www.gewinde-normen.de/en/index.html ----- thread standards
http://www.accuratescrew.com/info/SocketRef.htm
In this last one under point 14 there is something about LGLast edited by hiitsme; 11-12-2006 at 07:06 PM.
11-12-2006, 07:39 PM #3
11-12-2006, 07:56 PM #4
Hi Josip,
http://en.wikipedia.org/wiki/Screw
Originally Posted by from above link
http://en.wikipedia.org/wiki/British..._screw_threads
It looks like the 2BA just tells you the the thread pitch and size.
Hope that helps
11-12-2006, 08:34 PM #5
I didn't know that there is a European standard for screwing
Chemi
12-12-2006, 01:15 AM #6
12-12-2006, 06:53 PM #7
12-12-2006, 06:55 PM #8
Hi Josip,
this 2BA thing....
Doesn't it mean simply 2 pieces of screws which are BA standard????
12-12-2006, 08:56 PM #9
13-12-2006, 01:46 AM #10
Hi Josip,
B.A. stands for British Association thread form.
They range in size from 0 BA (the largest) which is about the same size as a M6, to I think about a 19 BA which is extremely small. The normal sizes are the EVEN ones 0,2,4,6,8,10,12. They used to be used alot for electrical equipment....still come across them in UK, but metric taking over.
2 BA is very similar to M5 and the 10-32 UNF. I think they will all thread in each other to a degree (some tight, some loose)
The material is not dictated to by the BA....you can get them in Steel and also in Brass. Normally have slotted heads.
The 3/4" LG would refer to the length (19mm). The Socket cap is the Head type which would be a recessed Hex (i.e Allen Key) probably with a knurled edge. I expect these to be Steel with a blackened oxide finish.
Hope this helps. More info on google.Last edited by Electrocoolman; 13-12-2006 at 01:53 AM. Reason: further info
13-12-2006, 02:37 AM #11
Originally Posted by Electrocoolman
Based on your description this sounds a lot like the tiny bolts used in safety heads on large recip compressors..
13-12-2006, 09:40 AM #12
Hi US Iceman,
Yes the black oxide finish screws are heat treated HT steel,.......but currently I cannot find any listed in a BA thread, but that does not mean that they aren't available.
17-12-2006, 09:42 PM #13
Hi, all
Found this on the net
Nothing about material but I believe any material we need we can use for.
Best regards, Josip
18-12-2006, 12:00 AM #14
Dear Josip,
I think you got all the answers already - all I can add is that BA threads are not much used these days, except in modelmaking and other hobbies. They are pretty small - like the screws that hold the cover plate onto an electrical socket. The LG reference I think was just an abbreviation for "long" - for example 2BA x 6LG is a 2BA thread 6mm long. 2BA only tells you the screw diameter and thread form.
cheers
Andy P
