Thread: Mitsu faults
    Apr 2001
    2,099
    27
    Mitsu faults
    I have a Mitsus currently playing up. Model PUH-2VK
    All the LED's light up except number 8. I hear a sound from the control board like a relay attempting to energise, but compressor does not switch on.
    Do I change the control board?? What tests can I carry out to check what is wrong with the control board, or relays?
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    Check that everything that you can test works as it should, if every thiing checks out then suspect the board, the board mounted relays are not replaceable, so I suppose that when they develop a fault they are scrap. One thought though, I had one unit with a seperate supply to the outside unit and the inside unit giving the same symtoms as your unit.(But I didn't realise this I always feed both units from the master isolator) I isolated both units overnight and when I powered them up in the morning they were as happy as larry.....Heres hoping
    If you badger D&W tech department they will send you Mitsubishis very good service manual.
    Karl
    Apr 2001
    Topeka, Kansas
    77
    Grumpy Mits'
    I had a customer that found this site for me. The distributor was completely helpless. This may be useful http://www.mrslim.com/index.html
    Bruce H. Robinson
    bhrobin@anchor-robinson.com
    company page: www.anchor-robinson.com
    personal page: www.anchor-robinson.com/bruce01.html
  1. Earth faults
    By reggie in forum Technical Speculations
    Last Post: 28-01-2006, 06:22 PM
  2. Mitsu Heavy Ind. Fault Codes...
    By Scooby in forum Air Conditioning
    Last Post: 08-12-2005, 08:37 PM
  3. Mitsu Heavy Industry
    By bobjob in forum Air Conditioning
    Last Post: 14-07-2005, 11:00 PM
  4. Mitsu
    By Abe in forum Air Conditioning
    Last Post: 05-01-2003, 02:19 PM
  5. Mitsu High Wall
    Last Post: 07-05-2002, 05:59 PM
