Results 1 to 2 of 2
Thread: samsung rs21dcns
21-11-2006, 11:53 PM #1
samsung rs21dcns
Hi there im new to this site and need help solving a very smelly fridge, its a american side by side fridge/freezer with which has a build up of ice around the pipe inside the back/bottom of the fridge have got rid of the ice once but its nowcome back and the smell is even worse, any suggestions
22-11-2006, 06:25 PM #2
Re: samsung rs21dcns
hello and welcome.
The pipe at the back is it a drain?
If it is the drain and is icing up then it may be blocked.
If it is the drain you ned to thaw out your fridge freezer and poke something through the hole to prove it is not blocked or to unblock it if it is blocked. Be very gentle doing this and PULL OUT THE PLUG on the mains lead first. While clearing the hole becarful not to push the pipe of the back or damage the pipe. When your happy it is clean pour half a cup of very hot water down it to flush it clean. Then every six months flush the drain with half a cup of very hot water.
Cheers taz.
