Results 1 to 12 of 12
    leosangel's Avatar
    leosangel Guest
    Exclamation Software Required!
    Is there any software from which we can measure that how much huge refrigeration unit is required for the room
    length n width and all dimesions of that room are given.
    11,024
    Re: Software Required!
    Last edited by Brian_UK; 16-11-2006 at 06:33 PM. Reason: Correct spelling of Coolpack and added link.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, Leosangel
    Quote Originally Posted by leosangel View Post
    Try to visit: http://www.luve.it
    and see to download program "Refriger 2006" maybe you must send an email to them asking for CD with that program.
    Best regards, Josip
    Oct 2003
    5,630
    34
    Leosangel,
    Even if you use software, event then you have to know what you need to input in the boxes.
    And you must be able to judge if the result is somehow in the region you expected.
    Be carefull with software.
    May 2006
    India
    82
    1,013
    Yes there are a number of softwares available for assessing the heat load for the refrigeration plant for a room. But you have to provide the necessary inputs. Merely by knowing the length, breadth and the height will not help. Coolpack is a good software and so is luve. Other than this you can directly download from www.russell.com and request for a software CD from www.heatcraftrpd.com . These are also useful selection software. If you visit the web site of Heatcraft as stated above, you can also get a chart for assessing the approximate heat load on the basis of the room dimension. But then that would not help you. For correct assessment you must have the necessary technical datas.
    Mar 2007
    South Africa
    228
    I think that Coolpack is a bit limited.
    Only allows 4 walls, roof and floor.
    What about freezer room with airlock?
    Only 2 products?
    No build in calculation for door infiltration.
    You also have to enter the heat of respiration.
    I suppose for a simple EES macro its not bad, but I wouldnt use it for commercial design.
    The original work done by Morten at DTU and publuished in Delphi source code was much better. Pity it was withdrawn.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, nh3simman
    Quote Originally Posted by nh3simman View Post
    Not agree, it is unlimited because it is free ask other people here....
    Only 2 products?
    What is problem with 4 walls, roof and floor if that room is round/circle it will be only 1 wall
    Airlock chambers with curtains are normal for industrial cold stores today in use are high speed curtains the lost is minimal...Why we need separate calculation
    It is possible to make calculation for more products but for each product separately, need more time, but...
    Calculation for door infiltration for me is no need because we have so many loss due to moving good in and out of freezer - never ever there is a constant load many times less then calculated for room..
    There are a lot of tables with heat of respiration values...
    I'm not an expert but for me CoolPack is more for industrial use...
    I have Daikin software Hi-VRV SELECTION PROGRAM for commercial A/C and it is completely different and not comparative with CoolPack, but you can try this one also free
    http://www.luve.it/EN/ -goto downloads- Refriger 2006 you must register
    Maybe, but was not compatible with new program and that was reason for withdrawn, who knows
    Best regards, Josip
    Feb 2008
    Sudan
    89
    Please I need the DAIKIN Software
    11,024
    Quote Originally Posted by 2007eng View Post
    Then ask Daikin for it.
    Feb 2008
    Sudan
    89
    Thanks Brian
    Feb 2008
    Sudan
    89
    [quote=Josip;62522]Hi, nh3simman
    This What I need.
    Oct 2001
    Nottingham UK
    5,667
    [quote=2007eng;96690]
    Quote Originally Posted by Josip View Post
    Hi, nh3simman
    This What I need.
