Results 1 to 8 of 8
Thread: 15 meters or more ?
10-11-2006, 09:02 PM #1
15 meters or more ?
High wall units from Fujitsu 3.5 Kw inverters ( ASY12BL) has any one experience of extending past the usual 15 mtr pipe runs as detailed in the install manuals. We will require 18 mtr piperuns to include a 5 mtr riser per system.
Any views or opinions greatly recieved.
Lrac
10-11-2006, 10:53 PM #2
Re: 15 meters or more ?
What do Fuji say about the extension ?
11-11-2006, 01:27 PM #3
Why not fit Daikin or Mitsi Elec. Inverters, 20m max run in 35 size?
11-11-2006, 01:38 PM #4
11-11-2006, 01:54 PM #5
Tell them that Fujitsu dont recommened going past 15m and they will void the warranty.
(I've spoke to them about this whilst fitting an ASY9, which was 10m max run, my run was about 10.8m, they said 1m extra would be ok but no more)
11-11-2006, 10:05 PM #6
I feel that the new fujitsu inverters will go to 20m as there recommended maximum.
they have 2 inverter wall mounts now, the ASYA12LCC & the ASYB12LCC. the B version (plasma) does 20 ms
I cannot show the link here but if you go to fujitsu-general.co.uk
airconditioning
wall mounts and then view brochures its will tell you what you need to know.
Best regards
Sarah
12-11-2006, 07:18 AM #7
Thanks s19652 i'll check that out.Nice to see you hanging around S.
regards
LracLast edited by LRAC; 12-11-2006 at 07:21 AM.
12-11-2006, 08:18 AM #8
I fit fujitsu a/c all the time,the info you require is on the installation sheet.From memory its 20grams per mtr over lenght.They work just fine at 20mtrs.Check out fujitsu web site for detailed info.
