    Blue Balls's Avatar
    Blue Balls Guest
    A pad that gets hot and cold when connected to a battery?
    Hello,
    Has anyone out there in fridge land heard of a flexible pad that gets hot on one side and cool on the other when connected to a battery or power supply? I need to know what they're called if possible and if anyone knows where to get some that would be great,
    Cheers,
    Mark.
    Apr 2006
    41
    1,620
    Re: A pad that gets hot and cold when connected to a battery?
    TEC, or PELT and they are not very flexible, and insanely inefficient.
    Jul 2006
    74
    865
    26
    Balls;
    It is known as the Peltier Effect.
    One Company that makes them is.
    http://www.ferrotec.com/products/the...FUscGAodRg3Q1g
    Mr. Pony is entirely correct. They are insanely inefficient. I worked for a company that used them and if I recall correctly they were about 40% efficient. For some applications they work, but for general use-not so well.
    I thought of all sorts of applications for them until I spoke to the Engineer who designed our systems. (We used them for cooling Lasers)
    Oct 2006
    Bucks, U.K.
    71
    604
    They are used in the small 12v cool/warm boxes and small fridges. They need a fan to blow air over the heatsinks (one cold, one hot). Current direction through the 'junction' determines which side gets cold and which side gets hot.
    They will only develop a fixed temperature difference across the junction of the two materials, and so the temperature of the cold side is governed by the ambient temperature of the hot side....the warmer the outside, the less cold the inside.
    I think thermocouples rely on the peltier effect as well but in reverse....heat generates a voltage.
    Put 'peltier effect' in google and look at wikipedia.
    rbartlett's Avatar
    rbartlett Guest
    http://www.coolchips.gi/
    cheers
    richard
    Apr 2006
    41
    1,620
    If you indeed apply heat to a pelt you'll get a current
