Which vapour compression ac units are suited to run in reverse as rankine cycle motors? Only those with rotary vane compressors, or will a centrafugal work as well? Scroll are damaged when reversed so they are out? what is the smallest unit with rotary vane? Cost second hand per Kw of rated input?
