    Oct 2005
    IRAN
    878
    Smile High back pressure compressors
    Hi everybody,
    Can someone explain the 'High back pressure compressors"? What is the difference and how is the compressor construction?
    Cheers.
    Even Einstein Asked Questions
    Jun 2001
    N.Ireland
    1,630
    Re: High back pressure compressors
    Hi Lana
    high back pressure usually refers to domestic compressors, larger motor for starting.
    In screws a different volume ratio is used, and with piston compressors, more valve spring pressure is usually used.
    Kind Regards Andy
    Oct 2006
    Bucks, U.K.
    71
    604
    Hi Lana...to repeat what Andy said, HBP is normally a term applied to Domestic/small Commercial (Hermetic) compressors.
    They are designed to cope with a higher evaporating temperature and are not so dependant upon the cooling effect from the return suction gas.
    You can use a HBP compressor in place of a LBP but not the other way round.
    If you look at the specifications you will see the HBP is evaporating at about +7 deg C and the LBP is at -25deg C.
    Hope this helps...regards Adrian
    Oct 2005
    IRAN
    878
    Smile Re: High back pressure compressors
    Thanks guys. Very helpful.
    I have been away very long. Where is Mark O'Brian?
    Cheers.
    Quote Originally Posted by lana View Post
    ............ Where is Mark O'Brian?
    Cheers.
    Sorry Lana, Marc decided to leave us a while back.
    Feb 2004
    132
    Why? I'll have to give him a call and break his British balls now!!
    May 2006
    china
    98
    Quote Originally Posted by Electrocoolman View Post
    Hi, guys! I convince "HBP" equal to "high evaporate pressure", but I don't consider "HBP" can be applied to "Domestic" range. Their application is different. And can a HBP be instead of a LBP??? It's impossible in most cases.
