Thread: hi everyone
23-10-2006, 11:21 AM #1
hi everyone
hi everyone on RE.. i just signed up and had a look around and already found this site extremely useful. just wanted to introduce myself, im scott, im 20 years old and im a second year apprentice from australia. hi to everyone and hope to hear from you all in the future.
23-10-2006, 07:00 PM #2
Re: hi everyone
Welcome Scott, glad to see that you are busy posting already
23-10-2006, 10:43 PM #3
Re: hi everyone
Hello,
A warm welcome from Belgium.
Don’t hesitate to ask any question and share your knowledge and experience with us.
This forum is read worldwide and you may expect a professional answer.
May I ask you to add also your location to the RE Members Map?
You can find it in the Green Top bar, the lower line.
If you post a question with the units you’re used to work with, place between brackets the other units. So if you normally work with SI units (bar, °C, m³/h..), place then between these units the proper IP units.
You can do the conversion with a free software program Uconeer
You can find it on http://www.katmarsoftware.com/uconeer.htm#download
Or you can use the spreadsheet of Dan posted on http://www.refrigeration-engineer.co...0617#post50617 post 6.
When you have a technical problem, try to post as many as possible readings you have made. You will see that we need many times condensing and evaporating pressure; discharge, suction, evaporator outlet and condenser outlet temperatures. Try to measure these very accurate.
The better you measure these, the better we can help you.
Note also band names, types of all the items installed in the installation.
I hope that you stay a long time with us and that you can contribute to expand this forum.
PeterIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
23-10-2006, 10:57 PM #4
Re: hi everyone
Hi, Scott_becks
welcome to RE
Originally Posted by Scott_becks
Check this link:
http://www.refrigeration-engineer.co...ead.php?t=6157
Best regards, Josip
29-10-2006, 06:42 AM #5
Re: hi everyone
thanks everyone.. nice to meet you all
29-10-2006, 09:17 AM #6
29-10-2006, 09:51 AM #7
Re: hi everyone
Always good to welcome a Oz on here.
A warm welcome to you
