Results 1 to 9 of 9
    kelamel's Avatar
    kelamel Guest
    LG Capacitor - Room not cold
    Hi all,
    I ain't a contract of air conditioning but i am located in singapore. Recently i had problems with my LG air con..
    I am using the LG split unit system in my home, one indoor unit is in my parents room and the other in my room.
    When both air con is switched on...both had warm air coming out, only the occasional cold air...then parents room air con was switched off , then my air con is v cold.
    contractor told me its due to a capacitor and he somehow is not able to get the exact LG capacitor used in the compressor.....
    any of u knows the brand/model of it so i could look it up over here on my side
    thanks a million!
    kelamel's Avatar
    kelamel Guest
    Re: LG Capacitor - Room not cold
    Its a 3 Head capacitor too.
    anyone knows the made and model ?
    thanks
    Oct 2006
    1,843
    21
    Quote Originally Posted by kelamel View Post
    thanks
    Capacitors are totaly inter-changable as long as you use the correct rating. On the side of the capacitor you will see a number with uF at the side of it. eg 30 uF that means 30 micro farrad.
    Your particular cappacitor should be some thing like 30/1.5uF +/-5%. It is just two capacitors in the same body.
    The make will be Nuintek in korea but any patten part will do.
    Just a quick question though. Why does your guysay the capacitor is faulty because the symptons you explain don't imediatly sound like a capacitor fault to me.
    Cheers taz.
    Oct 2003
    5,630
    34
    Quote Originally Posted by taz24 View Post
    Was just thinking the same Taz24. I don't think that the capacitor is the cause of your problem.
    Lack of gas when 2 units are working? Assume both are on 1 outdoor unit?
    Oct 2006
    1,843
    21
    My thoughts exactly.
    Cheers taz.
    Dec 2004
    Australia
    52
    519
    Some LG twin head multi units have two compressors.
    Is it possible the interconnecting wires are wrong?
    Oct 2003
    5,630
    34
    ...only the occasional cold air...
    What do you mean with this?
    Oct 2006
    1,843
    21
    The two evap controls are crossed over. The one bedroom evap calls for cooling but it brings in the other comp. Therefore the evap that is calling for cooling does not get any and the one that did not want it does.
    Cheers taz.
    Oct 2006
    1,843
    21
    Oh by the way the last post was not a definative answer to your problem just a possibility and confirming what Temprite stated.
    Cheers taz.
