    Oct 2006
    Bucks, U.K.
    71
    604
    Stainless Steel Evaporators
    Hi All...I'm new to the forum.
    Does anyone know of manufacturer who makes low profile evaporators with Stainless steel casing (available in UK). I'm in process of designing a Bakery retarder/prover using stainless steel coldroom due to low ceiling headroom on site. Appreciate any help.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Stainless Steel Evaporators
    You mean a stainless steel evaporating coil? Or a stainless steel shell and tube evaporator?
    Aug 2005
    5,302
    NoNickName,
    I believe he is asking for a unit cooler in a walk-in cold room. Since he said low profile I'm assuming it is a unit cooler.
    Beechy's Avatar
    Beechy Guest
    Hi Electrocoolman
    Searle manufactoring do such coils as we purchase them for acid environments, if they won't deal with you direct try HRP.
    Beechy
    Mar 2006
    Merate (LC) - Italy
    2,549
    Then try with LUVE, ALFA LAVAL or FRIGABOHN
    Oct 2003
    5,630
    34
    We use those of Goedhart and AIA Sweden.
    Oct 2006
    Bucks, U.K.
    71
    604
    Hi, to clarify.... I'm after a standard air blown (i.e. fans) evaporator with Cu coil and Al fins but with a stainless steel exterior casing (in lieu of normal Al or white finish Al). It needs to be low profile as it will be ceiling mounted. Cheers.
