Results 1 to 2 of 2
    Oct 2006
    Romania
    52
    13
    suction and discharge head for parallel compounding compressors
    Does anybody know a rule for calculating the diameter of suction and discharge head Copeland, Frascold so on compressors?
    Thank you!
    Oct 2003
    5,630
    34
    Re: suction and discharge head for parallel compounding compressors
    The diameter for the main header is not that important -take full capacity - but what's extremely important is how you connect the different compressors to that common header.
    Suction: make that all will return to the compressors.
    Discharge: make that header is lower then the compressors to avoid oil or liquid flowing back during stand-still.
    Bitzer has a very good bulletin about this. www.bitzer.de
    Read this once
    You're speaking about parallel compounding. For me parallel is something complete different as a compound setup.
