Thread: Quality of refrigerant
02-10-2006, 10:53 AM #1
Quality of refrigerant with respect to moisture and acid content is vety detrimental for unit operation.
I am looking for a method for determining exact moisture and acid content in ***** at site. Kindly enlighten.
02-10-2006, 11:49 AM #2
Re: Quality of refrigerant
There are degrees of exactitude.
Commercially produced indicators that you can use at site are unlikely to provide the accuracy to determine a precise level of contamination.
I would venture that this can only be achieved with a laboratory test of a sample in both phases, liquid and vapour, together with an oil sample.
Most of the major refrigerant suppliers will be able to analyse samples – though it is probably very costly – hence your question.
