Results 1 to 11 of 11
Thread: Domestic Ducted
20-09-2006, 10:17 PM #1
Domestic Ducted
Is there any sensible suggestions for domestic ducted systems. We keep being asked more and more this but there would appear to be very little choice on the market. Starting looking at the Unico system but seems very expensive and very unproven. has anyone fiited one yet or do you have any other ideas?
21-09-2006, 11:39 PM #2
Re: Domestic Ducted
Johnson & Starley used to do a 6kW R22 unit for location in the loft. Long and thin, and the condenser part would be ducted to atmosphere. Not sure if they have yet replaced it with a 407c/410a unit.
Otherwise, just a regular ducted split in the loft, maybe.
22-09-2006, 06:47 AM #3
Re: Domestic Ducted
Do you mean the 'cold-air side' ducted or both condensor and evaporator side?
22-09-2006, 08:18 AM #4
22-09-2006, 06:32 PM #5
Re: Domestic Ducted
it's still not clear for me, all the duct is in the void but are you looking for a monobloc unit or a ductable indoor unit which serves all the rooms?
22-09-2006, 09:01 PM #6
22-09-2006, 09:16 PM #7
Re: Domestic Ducted
Are all the rooms a similar size with similar heat gains?
If not, then a single indoor ducted unit serving all these rooms will have a control problem
25-09-2006, 02:47 PM #8
Re: Domestic Ducted
With one of those Johnson & Starley 6kW units, referred to above, I saw one installed with 4-outlets, ducted to three rooms. One large bedroom and 2 smaller ones. Obviously, the loads were different and, with different aspects, occurred at different times ofthe day.
Each duct had a motorised damper connected to a radio room stat. Seemed to wotk okay and the customer happy with it (3 years old).
21-10-2006, 10:02 PM #9
Re: Domestic Ducted
Thermofrost Cryo sell Johnson & Starkey, but I've no experience of these units
22-10-2006, 05:18 PM #10
Re: Domestic Ducted
The Johnson & Starley units were called CENTRE COOL. Done a couple a few years ago with an add on control pack with wireless stats. Worked ok The problem was that J&S did not have a replacement for the R22 model and they quickly put together what they had for the R22 deadline. They were then discontinued.The company that developed the wirless control and motorised dampers are still going and most ducted splits can be modified and controlled this way. If a client requests a ducted system we would normally provide a large split ducted with 3 to 4 outlets and either 1 main return air or seperate for each room. We would use polyaire circular plastic grilles suitable for 200mm dia insulated flexible ducting.Hope this helps.
22-10-2006, 05:56 PM #11
Re: Domestic Ducted
Hi Gents
we use UNTA and UNTB units from Rhoss.www.rhoss.com
Other Italian "chiller" manufacturers have similar. Aermec. Climiventa.
Argo also make split and concealed ceiling units.
Hope this helps.
Kind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
