Thread: Changing a stat
11-09-2006, 01:58 PM #1
Changing a stat
Hi Folks
trying to change a stat in a Schreiber apm 6235 SX fridge. Will a Danfos No3 do the job or will there be a specific stat( who makes these fridges?).heers in advance for any sugestions.
Jamboice
11-09-2006, 07:28 PM #2
Re: Changing a stat
Hi jamboice,
not sure who makes the fridges but you may be better to use a ranco vxo stat. it has a lowest cut out temp of -14, and the vt9 and the danfoss no 3 go down to -26 . sometimes those stats cause the system to run on too much and ice up. if the stat sensor is fixed to the front of the plastic liner i personally would go for the vxo.
good luck
12-09-2006, 05:09 PM #3
Re: Changing a stat
davej
cheers 4 that trying a No3 will see how it goes!
regards
jamboice
