Results 1 to 16 of 16
    Croatia
    68
    2,261
    Question Howden H&HP Screw Compressors
    Hi, all
    Howden screw compressor type MK2B/H255/16536 industrial, oil free (chemical industry) born 1973, needs general overhaul.
    Gas Propylene Oxide (Vi=77,88 m3/min = 2750 CFM)
    Speed 6960 rpm
    This is all I know now, so don't ask for more
    Waiting for some photos to upload here...
    I need compressor service manual.....help please, yes I will ask Howden but maybe someone here can help
    Best regards, Josip
    Aug 2005
    5,302
    Re: Howden H&HP Screw Compressors
    Hi Josip,
    I do not have any information on the dry Howden screw compressors.
    All of the information I have is for the oil injected models.
    Perhaps TXiceman will have some information or can direct you to a web address.
    Sorry my friend,
    US Iceman
    Croatia
    68
    2,261
    Hi, US Iceman
    Thanks, for other types I have documentation. This is something not used in refrigeration (I think so )
    I was hoping someone may have...let's see
    Best regards, Josip
    Aug 2005
    5,302
    I think you are correct Josip. The dry screws are mainly for process gas compression.
    Mar 2005
    638
    Afraid the best source of info will be Howden on the dry screws. This is pretty much a different beast than the oil injected machines.
    I don't have anything on them. It will have a separate lube oil unit that will more akin to an API lube oil console. Shaft seals may be a single mechanical seal or a gas buffered double seal.
    These machines are mostly used in process gas applications, often dirty gas service and have a much lower compression ratio per stage than a oil injected machine due to discharge temperature limitations.
    Ken
    Croatia
    68
    2,261
    here you can see exploded view of H&HP Howden oil free screw compressor.
    There we have 4 different fluids flowing through this machine.
    1. Working Gas (propylene oxid)
    http://www.scorecard.org/chemical-pr...nce_id=75-56-9
    http://en.wikipedia.org/wiki/Propylene_oxide
    http://www.google.com/search?hl=en&s...+oxide&spell=1
    2. Water (for cooling-double housing)
    3. Nitrogen (higher pressure then working gas to provide sealing at suction and discharge end between gas and oil because this gas is highly explolsive and flamable)
    4. Oil (for lubricating of slide bearings, journals and timing gear)
    Do not know to much, please see links
    Best regards, Josip
    alora's Avatar
    alora Guest
    Hello.I'm new on this site.
    I think it's very interesting especially this topic,because I work in a factory that produces propylene oxide and uses HOWDEN GODFREY LIMITED H255 compressors.We have some problems with this compressors, for instance over heating after general overhaul, maintenance in winter period when plant stops working.I have one more question - how much does it cost to remont the compressors and how much costs packing for compressors.
    Best regards, Alora.
    Croatia
    68
    2,261
    Hi, Alora
    Welcome to RE forums..
    Quote Originally Posted by alora View Post
    Are you working in Tuzla?
    As per my knowledge...general overhaul of complete unit/aggregate can come up to 70%-80% of the price for new one...maybe I am not right but hope some other members will come with their experience to confirm/deny me....there are a lot of points to be considered....
    Best regards, Josip
    SESHowdenHolima's Avatar
    SESHowdenHolima Guest
    Dear All,
    We have been packaging wet propane Howden compressors and have some experience overhauling them.
    Please do not hesitate to contact me if you are still looking for information.
    Regards Bas
    Kashif Aziz's Avatar
    Kashif Aziz Guest
    Can anyone suggest Howden refrigeration compressor packagers in USA?
    4,716
    Quote Originally Posted by Kashif Aziz View Post
    I suspect Howden USA will suffice?
    Follow the link
    http://www.howden.com/en/Businesses/...td/default.htm
    May 2009
    Glasgow
    8
    Hi Josip,
    Your compressor is indeed a bit different to the oil injected units normally discussed on this forum,we can offer you all the asisstance you may need, parts, service etc.
    please e-mail hpc.aftersales@howden.com for help.
    D.quals's Avatar
    D.quals Guest
    Howden HP Screw Compressors
    They say they are screw compressors, but look more like centrifugals. Regardless, I would think some oil in the system would be beneficial to lubricate the moving parts of the other components. Are there really refrigeration duty compressors available with this design?
    3,362
    D.quals I think you are getting confused as this is a gas process so its not normal in the refrig world way of thinking .
    If it were possible frig plants also would like oil free system like Turbochlor compressors .
    The Howden is definately a screw compressor
    Feb 2008
    the netherlands
    The Howden THP range is suited with labyrinth sealing. basic not a easy compressor if you are not familar with them. but they we are able to overhaul them.
    basel's Avatar
    basel Guest
    hi
    hi all i am fresh mechanical eng, and i saw this site hope to have a good expirence from older engineers,,
    ...bye bye
