Results 1 to 8 of 8
09-09-2006, 12:32 PM #1
Vauxhall (Opel) Astra evaporator - where is it?
My car a\c is not working too well
The gauges show evaporating at 2.4 bar and condensing at 7.5 bar, so the gas charge seems about right.
However, before doing anything else, I want to clean the evap. Where is it????
I can see the tubes going through the bulkhead but surely you don't have to rave out the whole radio\ventilation facia in the centre to console to get to it do you?
Steve
09-09-2006, 12:50 PM #2
Re: Vauxhall (Opel) Astra evaporator - where is it?
The chances are the evap is clean anyway. Have a look for any air intake filters just below the windscreen.
and go get a cuppa
09-09-2006, 06:39 PM #3
Astras use a variable displacement compressor, so very little can be learned from the pressures. Always ensure the correct charge by weighing the refrigerant in before you start pulling dashboards apart.
Karl
09-09-2006, 07:29 PM #4
How is this so
The compressors in my industrial background were variable displacement yet we still read pressures and so from that the evaporating and condensing pressures.
Displacement, so pumping capacity, varied as to the load on the plant as to whether more gas needed to be shifted from the evaporator.
The pressures on the Astra varied between 2.2 and 2.4 bar once the system had settled, but there was some apparent "switching" at one stage, but only by about 0.2 bar below those figures.
Also, the usual logic is you clean the evaporating and condensing elements first before making any judgements about gas charge.
Steve
09-09-2006, 09:22 PM #5
The same appears to be true with variable speed (Inverter) ac systems, perhaps someone with superior technical knowlage can explain why but with variable displacement compressors the pressures do seem to be constant for any given ambient irrespective of refrigerant charge (Down to a degree).
On any car it is always far easier to check the refrigerant charge first than it is to rip out dashboards or remove tons of plastic condenser cowling. So start there.Karl
09-09-2006, 09:40 PM #6
09-09-2006, 10:31 PM #7
the charge weight is on a label under the bonnet, on the slam panel I think. the compressor is a Delphi SP10 which I guess will be very similar in operation to the Delphi/ Harrison V5
Karl
09-09-2006, 10:46 PM #8
I am sure I've seen Delphi on the compressor body.
Steve
