    LRAC's Avatar
    LRAC is offline Veteran Poster I am starting to push the Mods: of RE
    Sep 2006
    Midlands
    453
    15 meters or more ?
    High wall units from Fujitsu 3.5 Kw inverters ( ASY12BL) has any one experience of extending past the usual 15 mtr pipe runs as detailed in the install manuals. We will require 18 mtr piperuns to include a 5 mtr riser per system.
    Any views or opinions greatly recieved.
    Lrac
    Re: 15 meters or more ?
    What do Fuji say about the extension ?
    Dec 2005
    Cheshire
    264
    Why not fit Daikin or Mitsi Elec. Inverters, 20m max run in 35 size?
    LRAC's Avatar
    Sep 2006
    Midlands
    453
    Quote Originally Posted by Slim R410a View Post
    Once agian the customer is king, we have tried to suggest Mitsi but the customer has had bad past experiences with mitsi and cannot be persuaded.
    The install entails 15 split units and yes the customer wants Fujitsu and all single splits god knows why.
    Lrac
    Dec 2005
    Cheshire
    264
    Tell them that Fujitsu dont recommened going past 15m and they will void the warranty.
    (I've spoke to them about this whilst fitting an ASY9, which was 10m max run, my run was about 10.8m, they said 1m extra would be ok but no more)
    Dec 2004
    59
    5
    I feel that the new fujitsu inverters will go to 20m as there recommended maximum.
    they have 2 inverter wall mounts now, the ASYA12LCC & the ASYB12LCC. the B version (plasma) does 20 ms
    I cannot show the link here but if you go to fujitsu-general.co.uk
    airconditioning
    wall mounts and then view brochures its will tell you what you need to know.
    Best regards
    Sarah
    LRAC's Avatar
    Sep 2006
    Midlands
    453
    Thanks s19652 i'll check that out.Nice to see you hanging around S.
    regards
    Lrac
    Sep 2006
    New Zealand
    54
    I fit fujitsu a/c all the time,the info you require is on the installation sheet.From memory its 20grams per mtr over lenght.They work just fine at 20mtrs.Check out fujitsu web site for detailed info.
