Results 1 to 10 of 10
Thread: Password
    Sep 2006
    MANCHESTER
    5
    Password
    help please. how to disable the password on eliwell id961 controller.
    Jan 2003
    East Anglia
    1,160
    Re: Password
    Password ?
    Never come accross that, what are you trying to do
    Normal you push and hold in order
    bottow right
    top left
    top right for 3 seconds and it should let you into the parameters.
    Let know exactly what you are doing and we might be able to give you a more precise answer
    fatboy
    11,025
    Re: Password
    Sep 2006
    MANCHESTER
    5
    Re: Password
    thanks for that but my model is id961 which is a single centre /off/on and not so complicated as the ewpc 961 regards
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Password
    go to parameter:
    PA1, PAssword 1. when enabled [value aotther than 0]
    it costitutes the access key for level 1 parameters.
    Tio make your life easier, try here,
    http://www.invensyscontrolseurope.co...LXeng42002.pdf
    Chemi
    Sep 2006
    MANCHESTER
    5
    Re: Password
    thanks for that. pa1 displays but no one has the password how do i get in with out a password.regards.
    Sep 2006
    MANCHESTER
    5
    Re: Password
    hi problem solved.hard slog with all possible combinations until the correct one did the job. thanks gentlemen to all concerned. regards.
    Oct 2003
    5,630
    34
    Re: Password
    Yamaha is asking - I think - anoter question.
    What if someone has entered a password and you want to change a parameter without knowing this password.
    You can go back then to factory settings.
    This is possible but I forgot how.
    I will give you the answer tomorrow after I have called my wholesaler.
    Oct 2003
    5,630
    34
    Re: Password
    Yamaha,
    Go as others said to PA , then SEt, then with the arrows up to 135 and again SEt.
    For the other controllers, the password is:
    EWPC...........13
    EWPX............13
    EWDB............PS1 =135........PS2=235
    EWDA/EWDL/EWDS/............PS1=PS2=135
    EWDC112/222......................71
    EWDC232............................13
    ID...................................135
    This is information you can't find on the Invensys/Eliwell website nor in the manuals!!
    Sep 2006
    MANCHESTER
    5
    Re: Password
    thanks for that PETER 1 good information.as you will see i am not a refrigeration engineer but a first line repair in a large food store. the refrigeration lads would have set there own password to keep fingers out. as i said all is sorted and thanks again.regards.
