    Mar 2006
    Norfolk
    160
    O Ring on Stal comp
    Hi Guys
    I am replacing a shaft seal set on a Stal comp with a 75 hp Storch motor running on NH3.
    In the shaft seal set I have two O rings the same size ( only one required) One of the O rings is marked "FPM".
    I believe that this "FPM" indicated the type of refrigerant that it is sutibale for - though I am not 100% certain.
    Can anyone give guidance as to which one to use on NH3.
    Thanks.
    Mar 2006
    Norfolk
    160
    Re: O Ring on Stal comp
    I will answer my own question so that the info is here if required in the future.
    The FPM O rings are for later applications i.e. heat pumps etc.
    Paula
