Results 1 to 9 of 9
    robbiedapict's Avatar
    robbiedapict Guest
    AMMONIA refrigerant
    I have a refrigerant related problem and I am hoping you can help me. The question is:
    A vapour compression refrigerator with AMMONIA as refrigerant works between 2.908 bara and 12.37 bara. Temperature after isentropic compression is 82 degrees C and the condensate is undercooled by 8 degrees C in the condenser.
    What is the COP (Coefficient of Performance) of the refrigerant?
    Looking forward to the answer or any pointers you can give me...
    Please help!
    Jun 2005
    CARDIFF
    61
    7
    Re: AMMONIA refrigerant
    you will need to find out the Cooling Capacity and the input power for the system
    Sri Lanka
    34
    According to the definition, COP is the amount of output, cooling or heating, you get for each unit of energy you spend on a vapour compression system. For a cooling application,
    COP = Cooling capacity (kw)/Power input to the system (kW).
    The power input may include all the ancillaries such as fans if you are looking for a realistic value. Otherwise, it is just the power consumption of the compressor.
    Oct 2006
    1,843
    21
    Quote Originally Posted by robbiedapict View Post
    Please help!
    Coolpack is your friend.
    Go to
    http://www.et.web.mek.dtu.dk/Index.html
    and follow the links to coolpack down load.
    You will find all the answers to your questions
    by putting the info you have given into the graph. It will tell you the COP.
    Cheers taz,
    Mar 2006
    Norfolk
    160
    Robbie
    This looks like a homework question - if we do it for you how will you learn?
    If I am wrong then sorry, and there is plenty of advice above.
    Paula
    Nov 2006
    63
    392
    COP=RE divided by WD you do not need the refrigeration duty just a pressure enthalpy chart and a calculator
    Ian
    Sep 2006
    Mindanao, Phils.
    257
    Hi robbiedapict,
    Why do you need the COP? For what purpose?
    Any refrigeration book could have answered your question.
    Paulajayne:
    Will you please answer the above question . . .
    Regards,
    Winfredy
    Last edited by winfred.dela; 19-11-2006 at 09:54 PM. Reason: spelling correction, add text
    Nov 2006
    63
    392
    I get it to 5.47 but surely you should have some suction superheat at the compressor which will change the COP a little
    Ian
    Mar 2005
    638
    Just read the text book and it will tell you exactly what the COP is defined as. Calculations are pretty straight forward. I agree that it sounds like a homework question.
    Ken
