Thread: capillary tube selection
30-08-2006, 01:19 PM #1
to make a working model of LiBr chiller of smallest size how to choose a capilary tube or expansion valve and what should be its size i.e. dia & length.
31-08-2006, 06:53 AM #2
Re: capillary tube selection
I have no experience at all but I think seen the many problems facing with a conventional cooling that it only can be done via trial and error.
It also has to be a steel capillary I suppose.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
20-09-2006, 09:42 AM #3
Give me the the ff data and I will size it up for you:
Refrigerant & Capacity
Evaporating Temp
Condensing Temp
Connection Size, Port & Configuration
12-03-2007, 01:50 PM #4
Do you have any theoretical method for that..
Best Regards,
ravi perumal
12-03-2007, 03:49 PM #5
Industrial Refrigeration from Stoecker has one but it's almost impossible to use this.
BTW, tho whom were you posting this question? Thread is rather old.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
12-03-2007, 03:52 PM #6
Hi there,
Please find the attached PDF file which gives what you want (I got them from this forum). I have another PDF file which is big in size and can not attach it. Give me your mail then I will mail it to you (this one is better ).
Also you can download a selection file for cap tubes from Danfoss site.
CheersLast edited by lana; 04-04-2007 at 12:31 PM.
Even Einstein Asked Questions
12-03-2007, 04:33 PM #7
hi,
Mostly i use the cap tube selection from acc group
you can look on www .the-acc-group.com
it's for me not possible the make a URLs so i do it this way
