Results 1 to 9 of 9
Thread: Emergency: suva 407 to R-22
24-08-2006, 11:17 PM #1
suva 407c is unavailable, could I revert to R22 without an oil change???????
24-08-2006, 11:26 PM #2
Re: Emergency: suva 407 to R-22
Originally Posted by greref
R22 will work with both mineral and polyester oil.......I think.
Need to have it confirmed by other members first.
25-08-2006, 04:05 AM #3
thats what they say. It works with both and I've seen a fiew builds using both
25-08-2006, 08:03 AM #4
Yes but you need to vacum the pipes and put new sintetic oil.Then it can work.
Renato
25-08-2006, 10:52 AM #5
The change is usually the other way around - why?
________
Chrysler Viper GTS-R specificationsLast edited by Argus; 07-02-2011 at 09:23 AM.
25-08-2006, 01:55 PM #6
Hi greref,
No problems, it works fine, I do it all the time.
All you have to do is check the evaporating temp, an adjustment to the TEV might be needed. No need to change it.
Good luck
Chemi
25-08-2006, 03:04 PM #7
If he need R407c then he has leek.When there is a leek sintetic oil is spoil for 2 or 3 hours.So he needs to change the oil.
Renato
25-08-2006, 11:26 PM #8
Thanks guys, I'll be steaming full ahead to make the crew of that vessel happy.....
Will post results...
26-08-2006, 02:08 AM #9
Assuming you do not haver leak??!
Yes ive done it when ive been unsure which gas the system uses.
R22 with work with both oils no probs, Its only when you use R407c you have to be sure you dont use mineral oil.
help me emergency 911
By tranquanghvac in forum Industrial CompressorsReplies: 4Last Post: 25-06-2006, 03:29 PM -
emergency, looking for a manufacturer
By Bob45 in forum Air ConditioningReplies: 1Last Post: 16-04-2005, 10:10 PM
