Results 1 to 8 of 8
Thread: Heat load help!
    Jul 2006
    London
    10
    Heat load help!
    I’ve got an unusual heat load calc for you guys, the room is domestic, effectively 4 external walls, 5m by 8m, 5m south facing, the ceilings starts at 3m and slopes up to 6m and 2m x 4m double glassed roof window, the walls and ceiling are without any insulation and there is little opportunity to add any. Also small fridge & freezer, DW, hob, oven and heating boiler. Would 150w/m2 (6kW) cut it?
    Any help welcome.
    Dec 2004
    Weihai,China
    800
    Re: Heat load help!
    On roughly estimation ,it's not enough with 150W/m2;suggest use higher standard 250~300W/m2,you can make a exact calcualtion if you have the heat transfer coefficient of wall and roof and windows. Only for your ref.
    regards
    LC
    Jun 2005
    Romania
    213
    Re: Heat load help!
    i thinck 200 w/m2 would be enough , true like LC says it's important what are the walls make of, and more important, how mutch heat load there is in the room, because that must be added to the calc
    Oct 2001
    Nottingham UK
    5,667
    Re: Heat load help!
    Quote Originally Posted by JAGw
    Any help welcome.
    Any chance of a picture as your description conjours up a seven sided building
    Seriously though, do you need to allow for the heating boiler? The 5 m width is south facing, but what is the construction? how much is glazed? does the glazed area have blinds?
    What is the configuraion on the glassed roof area? I can't picture it.
    Jul 2006
    London
    10
    Re: Heat load help!
    Quote Originally Posted by frank
    ... the roof window is double glassed and is 2m x 4m there is a double glased 5m bay window. The roof is tracota tile over old felt, Joists, then lath and plaster, no more than a foot thick.
    The walls are 1900s london yelow brick, 9 1/2", the floor is wood directly over concret. The boiler is not more than a concideration.
    JAGw
    Dec 2003
    uk
    21
    Re: Heat load help!
    I would go with 250 m2 and insist on cooling only.
    Cover my arse every time amd i dont get b*ll*cked.
    Jun 2006
    204
    Re: Heat load help!
    Frank, I like your new avatar. What did you say, I lost my train of thoughts. I guess we were talking about overheating or lots of heat or warmth or something like that...
    Oct 2001
    Nottingham UK
    5,667
    Re: Heat load help!
    Can't remember Larry - Too busy mowing
  1. online heat load calculators
    By pradyumna in forum Tools and Calculators
    Last Post: 07-09-2010, 06:42 AM
  2. Calculating heat load
    By Abe in forum Technical Discussions
    Last Post: 13-08-2010, 05:40 PM
  3. Heat Load calculation for residential jobs
    By Herschmidt in forum Air Conditioning
    Last Post: 12-05-2008, 11:50 PM
  4. frostles heat pump
  5. Mortuary heat load
    By smithgmp in forum Commercial
    Last Post: 05-05-2003, 04:43 PM
