    Dec 2004
    Weihai,China
    800
    industrial heat pump application
    Hi sirs
    Pls refer to the attached file for overview of heat pump application in industrial activities.
    I hope who have the experience to introduce some products in this field.
    thanks
    regards
    LC
    Jul 2006
    Orpington / Kent
    59
    11
    Re: industrial heat pump application
    Hi There,
    Can you be more specific !
    Dec 2004
    Weihai,China
    800
    Hi Sir
    I'm not familiar with industrial heat pump but I'm interested in its application in food and paper industry. Could you tell me something about that? thanks
    regards
    LC
    Aug 2005
    5,302
    LC,
    A heat pump can be used for just about any heating requirement. Any heat source is a good candidate.
    One of the biggest limitations is the final high temperature needed for the process. If we are using a common refrigeration system, we have to be selective for the refrigerant used.
    I'm working on a project now where the final temperature we are delivering is 170F (76.6C). I think we can get to 212F (100C) without too many problems. Maybe a little higher.
    Dec 2004
    Weihai,China
    800
    It's very fascinating it get above 100C final temperature. what is the critical tech? the specialized compressor and other component? tell me more if not against your confidential information
    regards
    LC
    Aug 2005
    5,302
    LC,
    The main issue is to design the system so that no critical application limit is approached or exceed. The main item to carefully evaluate is the compressor type and oil used.
  1. New Heat Pump Forum
    By Argus in forum Heat Pumps
    Last Post: 10-04-2010, 09:12 AM
  2. frostles heat pump
  3. Replies: 3
    Last Post: 06-11-2006, 05:04 AM
  4. Rebuild air2air heat pump
    By stalker in forum Technical Speculations
    Last Post: 02-11-2006, 10:10 AM
  5. heat pump capacity adjust
    Last Post: 14-02-2006, 07:32 AM
