Thread: industrial heat pump application
23-08-2006, 09:57 AM #1
Hi sirs
Pls refer to the attached file for overview of heat pump application in industrial activities.
I hope who have the experience to introduce some products in this field.
thanks
regards
LCLast edited by Lc_shi; 10-04-2007 at 09:39 AM.
23-08-2006, 11:00 AM #2
Re: industrial heat pump application
Hi There,
Can you be more specific !
24-08-2006, 01:56 AM #3
Hi Sir
I'm not familiar with industrial heat pump but I'm interested in its application in food and paper industry. Could you tell me something about that? thanks
regards
24-08-2006, 04:51 AM #4
LC,
A heat pump can be used for just about any heating requirement. Any heat source is a good candidate.
One of the biggest limitations is the final high temperature needed for the process. If we are using a common refrigeration system, we have to be selective for the refrigerant used.
I'm working on a project now where the final temperature we are delivering is 170F (76.6C). I think we can get to 212F (100C) without too many problems. Maybe a little higher.
24-08-2006, 06:40 AM #5
regards
24-08-2006, 02:48 PM #6
LC,
The main issue is to design the system so that no critical application limit is approached or exceed. The main item to carefully evaluate is the compressor type and oil used.
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
frostles heat pump
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM -
Rebuild air2air heat pump
By stalker in forum Technical SpeculationsReplies: 3Last Post: 02-11-2006, 10:10 AM -
heat pump capacity adjust
By Lc_shi in forum FundamentalsReplies: 5Last Post: 14-02-2006, 07:32 AM
