Thread: Heater elements
22-08-2006, 08:28 AM #1
Heater elements
Hi guys.
Just a general question about heater elements.
Is there a way to work out the maximum surface temp in deg. C or deg. F of any given heater element by formula?
1. If Max watts is known
2. If pwr supply is known.
A sparky once told me there was but I haven't found reference anywhere.
Cheers fellas.
rgds
Dogma
22-08-2006, 11:52 AM #2
Re: Heater elements
hi
if you will also give the type of surface then it will be posible(every type has its own specefications)
But I need to trace that formula for you.
Try to look at electrical books (basics)
It was 15 years ago when I study but remember it was there
Ill try to find my book
Cheers mate
23-08-2006, 12:29 PM #3
Re: Heater elements
Originally Posted by ALONEI
I pretty sure the ones I'm looking at are packed with magnesium oxide or sulphyde.
Does that help?
My quiry is how close These elements can be placed to certain materials if the materials flash pnt and or melting point are known.
If you could pass on the relevent text publication also it would be much appreciated.
Dogma.
23-08-2006, 01:58 PM #4
Re: Heater elements
Still looking mate.
I understand you are tallking about heat elements, in that case maybe the manufacturer can help?????
try them
Cheers mate
03-09-2006, 11:26 AM #5
Re: Heater elements
Ok mate. Will do. Cheers
Single pole contactor & crankcase heater
By herefishy in forum Air ConditioningReplies: 7Last Post: 01-04-2009, 08:38 AM -
Door Heater Tape
By Abe in forum CommercialReplies: 13Last Post: 20-05-2008, 06:38 PM -
Homemade Heat pump water heater
By busman in forum Technical DiscussionsReplies: 20Last Post: 05-02-2008, 04:04 PM -
Russell defrost heater wiring help
By Rob@goldcoast in forum ElectricalReplies: 10Last Post: 19-08-2006, 12:02 AM -
VFD heat pump water heater?
By star882 in forum New TechnologiesReplies: 0Last Post: 23-05-2006, 08:36 PM
