Results 1 to 8 of 8
    jacdu's Avatar
    jacdu Guest
    How do I Recharge-----
    Is it possible for me, a newby with the basic knowledge, to recharge an upright freezer. It uses 134a with the low side at 120psi. The pump runs but the unit doesn't get cold. Just what do I need to do, other that call a repairman.
    Thanks, jack
    Jun 2006
    Ireland(ROI)
    44
    28
    Re: How do I Recharge-----
    Quote Originally Posted by jacdu
    Thanks, jack
    Call a Techie, ffs man.
    Oct 2001
    Nottingham UK
    5,668
    The Low Side @ 120psi - on R134a ?
    Are you sure?????
    11,025
    120psi = probably is the test pressure shown on the label
    Jul 2006
    uk
    are you sure the compessor is pumping mate?
    Jul 2006
    New Berlin, Wisconsin, USA
    65
    57
    I agree with mr cool, looking at the pt card, it gives me around 98 degrees, if you are in Texas I can believe the ambient for a non running compressor, but if your not that warm, the compressor is running, your in trouble, the running motor is heating up the can, but not pumping anything.
    Oct 2003
    5,630
    34
    Thepump is running????
    In a fridge???
    Mar 2006
    Merate (LC) - Italy
    2,549
    The pump is running????
    In a fridge???
    No, it was a spelling mistake. He means the sump.
  1. the best way to recharge a VRV/VRF
    By marc5180 in forum Technical Discussions
    Last Post: 27-08-2007, 10:59 PM
  2. Honeywell coolmaster recharge
    By autochill in forum Trouble Shooting
    Last Post: 21-08-2006, 11:09 PM
