21-08-2006, 02:58 AM #1
Why no insulation in condensor unit ?
I'm curious why when A/C units are installed, why only the cold
line is insulated from the condensor unit to the evaporator.
Why is the cold line not insulated on the inside of the condensor
unit ? ...seems like an energy waste. Questions:
Is it ok to insulate the cold line inside the condenser unit ?
If not, why ? If so, would i see better efficiency ? ..thanks
21-08-2006, 03:32 AM #2
Re: Why no insulation in condensor unit ?
I'm guessing it is a fail safe to assure the system isn't slugged during worst case scenario.
21-08-2006, 03:38 PM #3
because the pipe that is cold, only gous to the compressor, so it's not a big amount of piping, it's a tehnical space, and teoreticaly not realy a necesity, and all the other pipes are hot
21-08-2006, 11:48 PM #4
Originally Posted by arrow201
21-08-2006, 11:56 PM #5
sorry i thought u were on about a beer cellar,the reason u have insulation on the expasion line is yet again is the point of expasion
need insulation
By jayjay in forum CommercialReplies: 16Last Post: 25-12-2006, 08:21 AM -
need insulation
By jayjay in forum IndustrialReplies: 0Last Post: 09-02-2006, 03:51 AM -
Suspended Floor Insulation
By Colin Kaminski in forum CommercialReplies: 2Last Post: 08-02-2006, 06:10 PM -
aeroflex inside access doors of ahu as insulation
By abbasi in forum FundamentalsReplies: 0Last Post: 31-10-2005, 09:19 AM -
Moisture bound insulation
By Temprite in forum CommercialReplies: 2Last Post: 18-05-2005, 02:57 PM
