Results 1 to 16 of 16
Thread: intek RK33
18-08-2006, 09:50 AM #1
intek RK33
G'day all
Was hoping that someone might be able to help me with a parameters list for an intek RK33 controller.
I have worked out that you can access paramater list by holding the set key.
Thanks in advance
19-08-2006, 10:09 AM #2
Re: intek RK33
Hi, I have full parameter list for rek33 if that anyhelp?
19-08-2006, 01:13 PM #3
Re: intek RK33
G'day alpha
If possible could you please send parameter list to:
Thanks in advance.Last edited by Temprite; 06-07-2007 at 02:51 PM.
19-08-2006, 04:21 PM #4
Re: intek RK33
Hi Temprite, the parameters should be falling through your inbox shortly, just sent em.
Regards.
20-08-2006, 12:35 AM #5
Re: intek RK33
Thanks alpha
exactly what I was after.
Many thanks.
05-07-2007, 08:21 AM #6
Re: intek RK33
I also need this Intek RK 33 controller parameters list. If someone could help me about this issue, i would be really appretiate. This is very urgent for me! Please help.
06-08-2007, 09:00 AM #7
Re: intek RK33
Re intek Rk 33
would it be possible if you can also send us parameters for controller. can't get hold of parameters locally.
would appreciate your response
thanks
07-08-2007, 12:27 PM #8
Re: intek RK33
PM me with email address and I will send
23-04-2009, 08:16 PM #9
Re: intek RK33
hi alpha,
im looking for the parametersfor the rk 33 controller. if you still have it can you aend it to me please
14-09-2009, 12:45 AM #10
20-09-2009, 10:29 AM #11
Re: intek RK33
hi, just enquiring do you know parameter list for rek 33 controller?
thanks
30-11-2009, 07:03 PM #12
Re: intek RK33
chilltec
email address
willoughby@onvol.net
22-12-2009, 01:53 PM #13
01-03-2010, 05:14 PM #14
Re: intek RK33
yes please, if you can help with setting ektron rek33, will much apreciate
08-03-2010, 11:56 PM #15
Re: intek RK33
Does anyone have the full set of Parameters and info for re-programming an Ektron REK 33? Cheers
22-07-2011, 10:43 AM #16
Re: intek RK33
Hello,
I need the list of RK33 too! Please per PM!
thx
