Results 1 to 11 of 11
Thread: Why no more 10 seer goodman?
16-08-2006, 02:27 AM #1
does anyone know why goodman(an american manufacturer) stopped producing 10 seer equip. now only 13 seer is smallest
16-08-2006, 02:39 AM #2
Re: Why no more 10 seer goodman?
ive answered my own question apparentely DOE regs. changed ,,,thanks
16-08-2006, 02:43 AM #3
I think you have it. I believe the 13 SEER ratings are the new minimum requirements for AC units.
18-08-2006, 10:31 PM #4
SEER ratings in the US are a measure of energy efficiency right?
In this day and age of permanantly reducing energy resources we can expect to see the numbers increase steadily as new technologies appear, such as inverter drives etc. Just as in the UK, all new equipment now must be sold with the Energy Efficiency Rating clearly advertised (A - G)
http://www.defra.gov.uk/Environment/...nergylabel.pdf
19-08-2006, 01:01 AM #5
Frank,
I can tell you everything I know about this in under 30 seconds.
The SEER stands for "Seasonal Energy Efficiency Ratio". It is a method of rating the units for energy efficiency. This way the consumer only has to know, the higher the number, the better the unit is for lower overall energy use.
That actually took longer than 30 seconds. Fat fingers!!!
01-09-2006, 06:42 PM #6
Is there a formula for converting the US rating to UK COP?
01-09-2006, 08:00 PM #7
There are two differences:
1) SEER in USA is in BTU/h per Watt or some such heathen units, whereas CoP is in kW/kW, so a SEER of 13 is equivalent to a CoP of 3.8 (divide by 3.415)
2) the "seasonal" part of SEER means that it is supposed to express the total cooling done over a year divided by the total energy consumed over the year. How do they know? Either its a "S.W.A.G" or the Weather Channel is more accurate than I thought CoP is the performance at a specific set of conditions - usually full load and design ambient so not very representative of real life.
Andy P
01-09-2006, 10:20 PM #8
To me the SEER rating is a lot like gasoline consumption in autos. Your mileage may vary, even if the rating is the same. It just a number to compare various units.
Sorry about the Andy. I forgot you don't use mileage as it is one of those heathen units of measurement.
01-09-2006, 11:01 PM #9
Now your making things confusing US Iceman!
You should know that Sierra Madre Ca. is 20 minutes from Glendale and not 13.8 miles?
Thanks Andy P for that enlightenment.
02-09-2006, 12:33 AM #10
[QUOTE=Andy P;48895]There are two differences:
Im with IceMan,Thanks Andy, I havent been called a heathen in alot of years, thanks for the laugh
02-09-2006, 01:37 AM #11
and we've got a star rating LOL, more stars more energy efficient.... it really helps to confuse customers alot - but at least from our end of business it has got alot of the cheap garbage off the market for the moment.
"Old fridgies never die, they just run out of gas!"
a/c seer
By Stuart in forum Air ConditioningReplies: 15Last Post: 07-01-2007, 12:58 AM -
Capillary Tubes
By subzero*psia in forum DomesticReplies: 19Last Post: 26-06-2001, 11:56 PM
