Results 1 to 11 of 11
    kevscontent's Avatar
    kevscontent Guest
    Samsung Error codes
    Help !,
    I have a samsung HH140ECM that has an error 'E0' on display and i am unable to find and info on the error codes for samsung, even tried samsung and they are not replying.
    Jul 2006
    Northern Ireland
    54
    Re: Samsung Error codes
    Hi, Had a look through my fault codes for Samsung ....its only a poor quality copy I aquired....and E0 isn't on the list but ED is which refers to Outdoor pipe thermister.
    I have some info on Trouble shooting using indoor and outdoor pcb's if that would be any help.
    Ian
    kevscontent Guest
    That would be great thanks, i have found out that E0 does exisy and it just means a general fault with the outdoor unit.
    Jul 2006
    Northern Ireland
    54
    Hi Hope these help......
    Trouble shooting by outdoor unit error
    [b]Error Error Description Check Code[/b]
    1 Indoor unit room thermistor Indoor PCB/
    Thermistor
    5 Indoor unit pipe sensor Indoor PCB/
    Sensor
    6 Outdoor thermistor/sensor Outdoor PCB/
    Sensor
    9 Float switch error Drain pump/float
    Drain system
    DIP switch SW2 of the indoor unit (the 2 and 4 switches must be on)
    A communication error indoor/ Inter connect
    Outdoor cable
    PCB of indoor/
    outdoor
    C Wired remote comms error Remote controller/
    Cable
    Main/Sub PCB of
    Indoor unit
    D Outdoor pipe sensor Outdoor pipe sens
    Outdoor PCB
    L Three phase power error Incoming supply
    ( 3 Phase models only) Outdoor PCB
    Sorry if this is a bit confusing as far as i can remember the outdoor unit has got a fault indicator on the PCB and the codes above relate to that. The error codes have a two digit format with the first digit indicating the unit address and the second the error code.
    Hope this is some help.... Most of the above tend to point to faulty outdoor PCB's as the cause of most faults.
    Ian Neill
    kevscontent Guest
    Ian,
    That is fantastic help thanks. Our problem points towards the compressor going out on thermal overload even after cleaning the condensor coil so its time for another call to Samsung !!.
    cheers for the help.
    Kevin
    markyp33's Avatar
    markyp33 Guest
    I don't want to teach you how to suck eggs, but if the compressor is going out on thermal overload have you checked you gas charge is okay. If you are low on gas this can cause it.
    Thanks - MarkyP
    Apr 2006
    stafford
    42
    974
    hey kev
    if samsung units give you anymore probs send me an email and should be able to help as just moved to a samsung firm(i know but the money is good!!!)
    paul
    Paul
    "KEEP IT COOL"
    sprinkler's Avatar
    sprinkler Guest
    Hi Ian
    i just installed a samsung mini split model AQV12V and when i turned it on a error code E556 came up any thaughts
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by sprinkler View Post
    Hi Ian
    Capacity miss-match!
    You need to set up option codes correctly.
    sprinkler's Avatar
    sprinkler Guest
    where would i find the set up options
    jason
    Split Croatia
    57
    6,151
    36
    If you where posted question in only one thread, you will be already found it.
  1. Samsung Error codes
    By kevscontent in forum Fundamentals
    Last Post: 04-04-2011, 08:08 AM
  2. samsung
    By superswill in forum Trouble Shooting
    Last Post: 20-07-2006, 09:20 PM
  3. Leaky Samsung...
    By charliepad in forum Domestic
    Last Post: 08-07-2006, 12:54 AM
  4. Samsung Domestic nightmare
    By andre_fridge in forum Domestic
    Last Post: 31-05-2006, 10:48 PM
  5. Anyone tried Samsung yet ?
    By eggs in forum Chit Chat & Service Stories
    Last Post: 27-09-2004, 10:58 PM
