Results 1 to 11 of 11
    Ireland
    47
    26
    Mitsubishi heavy industrial A/C.
    Hey there...
    I dont normaly work on Mitsubishi A/C units, but came across one today with the controller blinking
    on and off. It wont do anything. Changed it for another one but the same problem.
    Appreciate any information.
    ireland
    1,451
    41
    Re: Mitsubishi heavy industrial A/C.
    Had one that was being commissioned, nuetral was fed thru an rcd and was tripping, 3 phases were ok but no nuetral, only indication was controller blinking on and off
    have you correct voltage at controller??
    Al
    Ireland
    47
    26
    What voltage is meant to be at it do you know?
    There're 3 wires at the controller.
    No R.C.D on this system, just an 3 phase M.C.B.
    ireland
    1,451
    41
    Twas just the neutral that was fed from the rcd, the whole neutral block had been hooked up that way, not too sure on the voltage but i think it's either 12 or 5vdc?
    is the connection at the indoor ok?
    al
    Ireland
    47
    26
    There are about 14 indoor units, some are working, some aren't. Because half work and half dont is making it a bit of a problem.
    Jul 2006
    Northern Ireland
    54
    Hi Is there any fault codeit would usually start with an E number?
    Ireland
    47
    26
    Cant get a code because the controller isnt working for me. Its just blinking on and off.
    The outdoor unit isnt showing a code either.
    Green light on pcb board is staying on, whick is stand-by.
    Jul 2006
    Northern Ireland
    54
    Hi Can you give me any model numbers gas type etc and I'll have a look in my service data book.
    Ireland
    47
    26
    The outdoor unit is; FDC508HES3. (Sorry, dont have indoor Model).
    Gas is, R22.
    Thanks!
    Jul 2006
    Northern Ireland
    54
    Hi Some more questions
    Is this controller conected to 1 or multiple units?
    Whats the system history.....has any one messed up the configuration (multiple units) address codes etc , before you looked at it.
    If multiple units do all the outdoors show no fault?
    Can you get the indoor model nos? As I have details on indoor LED's which could maybe help with fault diagnosis?
    You may get more help from MHI technical people at 3D tel 01376565505
    Ian
    Ireland
    47
    26
    Thanks for that, Ian!
    We might be changing out the units, (so I was told this morning), but if they're staying, I'll give that number a ring.
    thanks again!
  1. Mitsubishi vrv
    By dakesojo in forum Air Conditioning
    Last Post: 22-09-2009, 01:04 PM
  2. Mitsubishi problem
    By marc5180 in forum Trouble Shooting
    Last Post: 17-01-2007, 10:06 PM
  3. Mitsubishi Heavy Industries HELP
    By Bakerbj in forum Air Conditioning
    Last Post: 26-07-2006, 03:18 PM
  4. MITSUBISHI Heavy Industries
    By coolit24 in forum Air Conditioning
    Last Post: 06-03-2006, 08:46 AM
  5. Mitsubishi Heavy Industry
    By Abe in forum Air Conditioning
    Last Post: 09-03-2005, 08:37 AM
