    ireland
    1,451
    41
    shining fault codes
    Anyone got fault codes for kelvin/shining wireless remote cassette units?
    Alec
    Oct 2003
    5,630
    34
    Re: shining fault codes
    KFR-23/26/34GW PANEL D
    - room temp sensor error: timer flash 1 time per 8 seconds
    - indoor coil temp sensor error: timer flash 2 times per 8 seconds
    - indoor fan motor error: timer flash 3 times per 8 seconds
    - cooling system error: timer flash 5 times per 8 seconds
    KFR-26/34/50GW PANEL V
    - indoor coil temp sensor error: 21¡æ and 30¡æ light on£¬ 22¡æ flash
    - cooling system error: 21¡æ and 30¡æ light on 25¡æ flash
    - room temp sensor error: 21¡æ and 30¡æ light on 23¡æ flash
    - indoor coil temp sensor error: 21¡æ and 30¡æ light on 24¡æ flash
    KFR-70GW PANEL V
    - room temp sensor error: 21¡æ and 30¡æ light on£¬ 22¡æ flash
    - indoor coil temp sensor error: 21¡æ and 30¡æ light on 25¡æ flash
    - indoor fan motor error: 21¡æ and 30¡æ light on 23¡æ flash
    - cooling system error: 21¡æ and 30¡æ light on 24¡æ flash
    KFR-23GW PANEL H (the old one)
    KFR-50LW/70LW/120LW
    - anti-frozen during cooling:E3
    - system protection:E4
    - room temp sensor error:E5
    - indoor coil temp sensor error:E6
    - Outdoor coil temp sensor error:E7
    - Overload protection:E2
    - E9 High-low pressure switch
    KFR-50QW/70QW/120QW
    - indoor air inlet temp sensor error: RUN light flash 1 time per 8 seconds
    - indoor coil temp sensor error: RUN light flash 2 times per 8 seconds
    - cooling system error: RUN light flash 3 times per 8 seconds
    - overload protection: RUN light flash 4 times per 8 seconds
    - communication error: RUN light flash 7 times per 8 seconds
    ireland
    1,451
    41
    Peter
    thanks very much, that's sorted the problem!
    Al
    GEX's Avatar
    GEX Guest
    Bearing in mind that i might sound like an idiot
    what exactly does: 21¡æ and 30¡æ light on£¬ 22¡æ flash mean?
    thanks
    Godwin
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. carrier chiller fault codes
    By al in forum Air Conditioning
    Last Post: 20-07-2009, 10:10 PM
  3. Daikin fault codes
    By Markie in forum Air Conditioning
    Last Post: 13-01-2009, 01:58 AM
  4. Chigo Cpa-09co Fault Codes? E4?
    By chigosimon in forum Trouble Shooting
    Last Post: 24-11-2007, 12:46 AM
  5. MHI, Sanyo & Fuijitsu Complete Fault Codes
    By aeb200 in forum Air Conditioning
    Last Post: 16-11-2005, 01:11 PM
