Results 1 to 8 of 8
Thread: Gram plus F660 L freezer
06-08-2006, 04:36 PM #1
I bought a Gram plus F660 L used freezer recently. The problem is that it donīt go below -9 C.
The cold side of the compressor gets full of ice. The refrigerant is R290. Both fans inside and outside are working well. ANy sugestions?
Sven
06-08-2006, 05:23 PM #2
Re: Gram plus F660 L freezer
Sounds over charged, was it orrigionaly R-22 then converted over?
If so then over charged as you need so litle with R-290
06-08-2006, 10:20 PM #3
Originally Posted by wallwall
Please explain what you mean by the cold side of compressor?
Yes, true , the low side does return evaporated gasses which are cool...........but if the pipe is iced over......as previous poster has mentioned.........overcharge is likely
06-08-2006, 11:06 PM #4
Itīs loaded with r290 from the beginning.
Somebody has filled it before I get it! I dontīt know who it was or what he used to fill it.
Clean it and recharge
06-08-2006, 11:10 PM #5
Ja that would be my sujestion as well, Vac, new Filter dryer, new oil (Why not certainly will not hurt) and a properly weighted in charge, that will have a purring away (I wuve R-290 )
07-08-2006, 09:53 PM #6
have you tried DEFROSTING it?
07-08-2006, 09:57 PM #7
One would tend to immagine it would defrost rather well durring transport, but non the less a good idea to duble check.
08-08-2006, 04:52 AM #8
Yes, it was completly defrosted, about +30 C
walk in freezer refrigeration sizing?
By trammd in forum Technical DiscussionsReplies: 10Last Post: 02-11-2006, 11:56 AM -
Freezer operation in my garage
By sonjand in forum FundamentalsReplies: 5Last Post: 02-08-2006, 10:25 PM -
please help with Kenmore Upright Freezer
By lrn376 in forum Trouble ShootingReplies: 0Last Post: 09-07-2006, 10:40 PM -
Help! fridge freezer probs
By Glenreed in forum Trouble ShootingReplies: 2Last Post: 06-01-2006, 10:51 PM -
Fan quit in freezer compartment.
By odam2k in forum Trouble ShootingReplies: 4Last Post: 05-07-2003, 02:18 PM
