Thread: R410 manifolds
04-08-2006, 10:30 PM #1
R410 manifolds
Am i being dumb!! just got a new set of 410 manifolds after my old set that i got 2nd hand went missing.
first job to press test a/c unit and found the new yellow charging hose,that you would fit to normal nitro fitting or bottle is the same size as the 410a fittings on the a/c
so it will not fit the nitro or a vac pump
do i need a fitting or something!!!!!!!!! i can only assume the old set had been modified by others as it had normal 1/4 fitting.
04-08-2006, 11:36 PM #2
Re: R410 manifolds
This set comes with standaed yellow hose and two 1/2" (red,blue)Two Way R410A Manifold with Charging Lines
Two way manifold with high quality aluminium body with sight glass. Bourdon type gauges, hook, 3 charging lines - connections 2 x 1/2" - 20 UNF (blue and red) and 1 x 1/4" SAE (yellow), length 36" (900 mm). Supplied in a sturdy plastic case. Temperature scale for gas: R410A. Pressure scales : bar and psi.Part
04-08-2006, 11:53 PM #3
Re: R410 manifolds
mine has 1/2 charging line........... does anyone know if their is a 1/2m to 1/4f adapter
05-08-2006, 09:56 AM #4
Re: R410 manifolds
Refco manifolds for 410A seem to have 1/4 vac hose fitting but my Cps manifold is UNF and you need an adaptor .
SRW part No 100202 www.srwonline.co.uk
Hope this helps
07-08-2006, 02:20 PM #5
Re: R410 manifolds
cheers birds! on order .
want good price r410 flaring tool in aust ?
By peter1927 in forum Tools and CalculatorsReplies: 2Last Post: 24-11-2005, 05:48 AM -
R410
By Vincent Yu in forum FundamentalsReplies: 2Last Post: 19-10-2005, 01:10 AM -
a/c Cfc free R410 refrigerant changes
By ksvinod in forum Technical DiscussionsReplies: 3Last Post: 10-09-2005, 11:51 AM -
R410 reclaiming
By chillin out in forum RefrigerantsReplies: 2Last Post: 20-07-2005, 09:59 PM
