03-08-2006, 05:27 AM #1
Tinkering with an old Ref glass display case
I think I may have a High Low limit switch problem.Iam pretty sure someone adjusted it, not knowing what they where doing. I know I prob need more info but can anyone tell me what the switch might need to be set on???
03-08-2006, 09:59 AM #2
Re: Tinkering with an old Ref glass display case
HI,
What refrigerant is the unit working on?Brian - Newton Abbot, Devon, UK
03-08-2006, 10:59 PM #3
Originally Posted by fix_it_man74
regards Toosh
07-08-2006, 02:35 PM #4
Turn or unplug the power supply and bridge out ( electrically ) all the controls then turn it back on at least you will know if its the controls or the system is dead first .
So if it goes then take out the bridging and trace which control is open circuit and stopping the operation of unit . If its the LP just narrow the differential that is probably too wide and holding the unit out.
display case evaparator fans
By Mark in forum Supermarket RefrigerationReplies: 68Last Post: 16-01-2011, 03:03 AM -
Need help with a dual compressor display case
By kengineering in forum Technical DiscussionsReplies: 15Last Post: 15-03-2006, 07:32 PM -
display case temp alarms
By shark26 in forum Supermarket RefrigerationReplies: 9Last Post: 17-01-2006, 10:07 AM -
Fogal Open Display Case
By Abe in forum CommercialReplies: 2Last Post: 07-05-2005, 08:47 PM -
Big Display Case
By Abe in forum CommercialReplies: 4Last Post: 02-07-2003, 10:53 PM
