Thread: Storing refrigerant cylinders
02-08-2006, 10:28 AM #1
Hello i need to store some refrigerant cylinders in a lock up, what legal things will i need to think about such as warning stickers etc.
Regards Mark
02-08-2006, 11:21 AM #2
Re: Storing refrigerant cylinders
At the least you should post some 'compressed gas' signs, probably also have a COSHH list inside.
Also consider ventilation requirements.
Is it a rented lockup and does the lease allow storage of such items.Brian - Newton Abbot, Devon, UK
02-08-2006, 11:32 AM #3
Brian thanks for the reply, the storage is a large metal container lorry type thing owned by our company, i have ordered a compressed gas sticker from RS, i will print off a COSHH sheet from HRP and laminate it, will think about the ventilation side.
Regards Mark
02-08-2006, 12:22 PM #4
Also sort out chains or straps to ensure that they cannot fall or get knocked over. If the storage is to be long term think about detection equipment.
Paula
02-08-2006, 01:02 PM #5
Wof56,
The BCGA (www.bcga.co.uk) guidance note GN2 "Safe Practice for the Storage of Gases in Transportable Cylinders intended for Industrial Use: Rev2 1997" would be appropriate reading.
Also refer to BOC Publication "Safe Under Pressure" phone 0800 111 333 document No SFT/007875/APUK/0604/20M covers how to work with, store and handle gas cylinders safely. They also run "Hazard Awareness with Refrigeration" safety seminars which covers storage of cylinders. Phone 0800 02 0800
Hope this helps.
02-08-2006, 04:53 PM #6
Thanks for the advice everyone all points noted and acting on.
Regards Mark
R600 Refrigerant.
By tonydeith in forum RefrigerantsReplies: 14Last Post: 21-04-2011, 08:52 AM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
Refrigerant heel in supply cylinders.
By Miki in forum RefrigerantsReplies: 3Last Post: 23-08-2006, 10:52 AM -
Liquid refrigerant and bubles in sightglass
By aygul in forum Trouble ShootingReplies: 2Last Post: 30-08-2003, 09:07 PM -
Refrigerant Reclamation
By herefishy in forum CommercialReplies: 6Last Post: 23-07-2003, 08:19 AM
