Thread: Glycol to heat flooring problem
31-07-2006, 11:36 PM #1
I havent had a chance to look yet but it seems as if we may have a slight blockage on our floor warming system. if this is clogged how do you guys flush the system and clear the clogged portion. it runs alt least 100 down and back. we have a metal line running the the area of the freezer then has hose connections that go into the concrete if this helps.
01-08-2006, 01:13 PM #2
Re: Glycol to heat flooring problem
Can you isolate any of the other circuits? If you can valve the open circuits off and maybe the added pump pressure will flush it.
Do you have flow indicators anywhere?
Whats your pump pressure?Last edited by nh3wizard; 01-08-2006 at 01:15 PM.
Heat Reclaim
By chilled2005 in forum Supermarket RefrigerationReplies: 19Last Post: 05-05-2008, 05:32 PM -
frostles heat pump
which glycol to use ?
By dchatta in forum RefrigerantsReplies: 4Last Post: 12-07-2004, 09:26 AM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM
