    Apr 2001
    2,099
    27
    Evaporating Pressure
    What should the "ideal" evaporating pressure be on a R410 split air conditioning system, in cooling mode in a 30C ambient
    Should it be around 150psi ( which is evap temp +10C ) or should it be less.
    On a pre charged system how is the charge adjusted??
    Same question for R22
    Thx in advance
    Oct 2001
    Nottingham UK
    5,668
    Re: Evaporating Pressure
    Quote Originally Posted by Abe
    Thx in advance
    Typical mistake Abe.
    Never refer to pressures. Look at temperatures using the Saturation tables for the gas you are using. With Air Conditioning you should aim to keep your evaporating temperatures above freezing to avoid frosting on the evaporator. With R22 the saturation temperature at 0C is 49.7psig so most "eng'rs" look for a suction pressure of 50/55psig which ensures that the evap stays free of frost. Likewise you need to look at the sat temp of R410a (sorry, I don't have it to hand) for 0 - 5 C saturation pressure.
    from experience it is about 7.5bar
    Apr 2001
    2,099
    27
    Thx Frank
    Actually this morning when I posted , I did really mean evap temp, not pressure.........Grrrrrrrrrrrrrrrr But what the heck
    Ive printed it out
    Appreciate your help
    Picked up an order for 6 systems today, ranging from a couple of wall splits, to cassettes and one floor mounted
    and.............also got a cold room!!!!!
  1. This a long one - AKV
    By Peter_1 in forum Industrial
    Last Post: 26-12-2008, 11:47 AM
  2. Building a wine cabinet
  3. TEV capacity related to pressure drop
    By DaBit in forum CPU Overclockers
    Last Post: 06-12-2002, 05:11 PM
  4. oil pressure problems on air dryer
    By edge in forum Trouble Shooting
    Last Post: 16-07-2002, 02:10 PM
