Thread: Newbie questions
30-07-2006, 11:20 AM #1
Newbie questions
Finaly due to our heat wave here in Belgium I bought a split airco.
The unit is equipped with so called quick connections and comes with 4m pipes.
According to the manual you can all install it yourself.
Still I have some questions:
- Is it not adviced to have the unit vacumized
- I would like to extend the pipes, is this possible?
- If yes how is this done best, new pipes with both sides quick connections or remove connections and extend pipes and put connections back on?
- The outer unit is filled with gas, what about the inner unit, some say the are filled with compressed air others say they are vacumized?
Thx
30-07-2006, 11:54 AM #2
Re: Newbie questions
dear
no vacuum is needed ,,for both outside or inside , just connect the pipes , remember to connect the inside unit first.
some of splits comes with 5 meter long pipes ,
elongate 2 meters more is not that problem , but you must vacuum and charge the pipes , or (if it is not possible ) connect the pipes (after elongate them) and vacuum the whole system
afeef
30-07-2006, 11:40 PM #3
Hi Racemier and welcome.
Your unit will have been pre-charged with refrigerant in all three components, the outdoor unit, the indoor unit and the connecting pipework.
Or.... The outdoor unit will be pre-charged and the other items will be under vacuum - this is unlikely however, go with option one.
If you want to extend the length of the connecting pipework you really should contact a technician who is qualified to to the work which entails:-
Recover refrigerant from the pipeline.
Cut and extend the pipeline.
Pressure test the pipeline.
Evacuate the pipeline.
Recharge the pipeline with the correct amount of refrigerant.
Hope this helps.Brian - Newton Abbot, Devon, UK
Interview questions
By zimbo in forum Chit Chat & Service StoriesReplies: 16Last Post: 10-09-2008, 10:06 PM -
EVAPORATOR CHARGE ---> Questions
By KETTLER in forum FundamentalsReplies: 5Last Post: 14-03-2007, 10:55 PM -
questions
By parry in forum Chit Chat & Service StoriesReplies: 17Last Post: 31-10-2005, 08:46 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM -
newbie questions.......
By krusty in forum FundamentalsReplies: 3Last Post: 30-04-2002, 07:55 PM
