    Apr 2006
    1,620
    Superheat Correction facter for R12-TXV - R134a?
    Ok I have a Singer M:207C TXV for R-12 (Same as the american Control company TXV) it comes preset to 9F (-12C) superheat.
    It is a 6,000BTU/hr unit (1.76 KW/hr) liquid cross charged head internaly equilized
    I'm thinking I need to set the super heat higher for it to work correctly with R-134a correct?
    Thanks guys for any Help.
    Head pressure during pull down is 150PSI
    Aug 2005
    5,302
    Re: Superheat Correction facter for R12-TXV - R134a?
    Quote Originally Posted by The MG Pony
    it comes preset to ... (-12C) superheat. ...
    You must have made some kind of error in your calculations.
    If you are running a negative superheat, that is a unique kind of refrigeration system you are working on.
    If the evaporator has any appreciable pressure drop, the internally equalized valve may not remain stable no matter where it is set at.
    Croatia
    68
    2,261
    Hi, The MG Pony
    I think in this case this 9F means 5K or 5C but only like a difference, because the superheat we always write in K and K is always positive number, there is not negative temp shown in K scale at all.
    So if you run your sistem at 9F(-12,778C) your superheat will be 18F(-7,778C) (difference of 9F or 5K or 5C)
    For *****s it is Ok to have min of 5K, with ammonia you can go to 0K.
    Best regards, Josip
    Apr 2006
    1,620
    This is what I read off the TXVs manual it is presset to 9degrees fehren?
    I guess there is no sort of correction facter eh? just a good thermometer and a set of guages and some time tuning it all?
    But if it is going as a differance then is there some basic way to set it correctly to work with R-134a? IE Increasing super heat or reducing it slightly to match the R-12 curve.
  1. Carrier 23xl chiller-Low discharge superheat alarms
    By Bradysmill in forum Trouble Shooting
    Last Post: 25-04-2010, 07:43 PM
  2. Superheat
    By shogun7 in forum Fundamentals
    Last Post: 23-08-2004, 05:54 PM
  3. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
  4. How do you calculate Superheat?
    By zolar1 in forum Training
    Last Post: 10-05-2002, 02:37 AM
