Results 1 to 2 of 2
    Mar 2024
    1
    Help! How do I remove valve core on this Toshiba RAS unit???
    Hi, I can't get enough clearance on my valve removal tool to get the valve out on this Toshiba RAS unit so I can vacuum down. Any tips or advice would be really welcome!IMG_20240319_113739940.jpgIMG_20240319_113750674.jpgIMG_20240319_113756226.jpg
    Feb 2011
    scotland
    453
    Re: Help! How do I remove valve core on this Toshiba RAS unit???
    Could you carefully bend the copper pipes to move the expansion valve out of the way? Being careful to not go too far as to kink the pipes.
    Could you take the coil off the expansion valve?
    Interested to hear about opportunities to learn - linkedin.com/in/s34nf
