Results 1 to 12 of 12
28-07-2006, 01:35 PM #1
I want to make a room: 14',9',9' cool
Hi there
Im a total newb so go easy
Im in a high rise block so i cant attach any equipment to the outside of the building.
In the room i have a G5 running and 2 powerfull 150w active speakers adding to the warmth.
there are three large north east facing windows.
I dont want to spend much money especially as i'll only be using the cooling a few weeks a year (england) and if it could also do a spot of heating in the winter that would be great. so please could u recomend me a system
28-07-2006, 10:45 PM #2
Re: I want to make a room: 14',9',9' cool
Hi, welcome to the forum.
Is it possible for you to fit a through the wall unit or a through the window unit ?
I don't expect that you can really knock a hole in the outside wall so perhaps we'll forget that one
Do you have an opening window that would allow the temporary fitting of a sheet of wood with a thru' unit fitted ?
PS, What's a 'G5'?Brian - Newton Abbot, Devon, UK
29-07-2006, 06:56 AM #3
Do you have a balcony?
29-07-2006, 07:15 AM #4
Originally Posted by Andy W
Surely it's not that serious!!
Richard
31-07-2006, 07:51 AM #5
Originally Posted by Brian_UK
ive worked out that it would be quite simple to replace one of the smaller window panes with a wood panel in which i could cut a hole in for an Exaust hose. Which i guess would narrow it down to portable units, been doing my homework
i came across this model from Junwel(??) but i cant tell if its as good as it looks in the pictures..does look tasty tho
http://www.junwel.com/product/90/495/702
p.s. unfortunately i dont have a balcony, thanks for the help peeps
31-07-2006, 11:13 AM #6
Ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...category=20711
Paula
31-07-2006, 07:40 PM #7
Originally Posted by Paulajayne
31-07-2006, 10:30 PM #8
Nice looking product there Paula, interesting power usage though ???
Cooling:-
Output - 3.2 kW
Input - 0.95 kW
Heating:
Output - 2.0 kW
Input - 2.05 kWBrian - Newton Abbot, Devon, UK
03-08-2006, 04:22 PM #9
Well spotted Brian
Defies the laws of physics on the cooling side -
Paula
09-08-2006, 10:03 PM #10
10-08-2006, 12:09 AM #11
do you own or rent? If you own and you have lots of money, we have installed ducted splitsystems for people,in apartment buildings. they have a huge pipe run and these went up 3 floors to the roof plant room.
If you rent possibly somthing portable would be ok. You can just unplug them and take them with you, but they generally arent as effiecent as split systems. I would avoid window units because they can be quite noisy and might upset the neigbors
i would avoid buying the cheapest model on the market, and i woudnt buy somthing based onhorse power, buy it on its kw capacity. trust me, paya little more and get a brand with a goo reputation. Daiken is normally the best if you can afford them. Mitsubishi heavy are alo very good units.
Hope that helps
10-08-2006, 12:15 AM #12
oh and if possible go slightly larger in unit capacity. It is much better (in my experience) to have a larger unit working less and changing the temperature easier than a smaller unit that consumes a lot of electricity and struggles to change the temperature
hope that helps
Cool Room Problem
By hybridjunction in forum Trouble ShootingReplies: 34Last Post: 31-01-2007, 11:09 AM -
troubleshoot a two door storage room
By duraid in forum FundamentalsReplies: 7Last Post: 13-12-2006, 06:57 AM -
Cheese Room Design 24V DC
By jbelding in forum FundamentalsReplies: 10Last Post: 02-04-2006, 03:23 PM -
Installation of cold room
By Josip in forum Legal-Business-MarketingReplies: 12Last Post: 12-03-2006, 09:20 PM -
Freezer Room Panels
By Feeze in forum Technical DiscussionsReplies: 10Last Post: 22-04-2005, 05:58 AM
