Results 1 to 8 of 8
Thread: Airwell
27-07-2006, 10:48 AM #1
Airwell
What is the best way to check Airwell unit?
i mean there is no contatctor no lights on pc board?
I turnd on circle breaker unit strats strait awey on cooling and i want heating . replaced pc board indoor unit still doing it?
27-07-2006, 12:24 PM #2
Re: Airwell
Airwell are only working in the northern emisphere, so in summer they start cooling. :-)
27-07-2006, 04:43 PM #3
Re: Airwell
What model is it?
28-07-2006, 10:06 AM #4
Re: Airwell
hmm its got revrcing valve so that means its working on heating too but the problem is when i turn circle braiker on unit starts on cooling. my question is why the unit starts on cooling and i set remont control on heating.(i replaced pc board) i just want to now what starts unit?
28-07-2006, 04:43 PM #5
Re: Airwell
Is it to warm to call for heating?
28-07-2006, 07:51 PM #6
Re: Airwell
Hi cool and heat signal comes from indoor pcb make sure you havent got a relay which is sticking on the board.... These are the worst units i have ever worked on.sorry cant help any more than that
29-07-2006, 04:42 AM #7
Re: Airwell
Originally Posted by Ian Neill
Heres a basic question for the no heating AIRWELL because I would look at this first , is there power to the reversing valve when its calling for heating ? Could be as simple as that a stuffed coil on rev valve.
30-07-2006, 08:57 AM #8
Re: Airwell
thanks to all of you
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Airwell Air Conditioners?
By racs in forum Air ConditioningReplies: 10Last Post: 02-03-2008, 07:52 PM -
airwell ac
By thebigcheese in forum Air ConditioningReplies: 5Last Post: 27-07-2007, 11:15 PM
