Thread: daikin AF fault
27-07-2006, 09:35 AM #1
daikin AF fault
hi guy's
a customer keeps getting this on a few of in ceiling ducted units
any idea's
cheers
richard
27-07-2006, 11:15 AM #2
Re: daikin AF fault
if its a daikin sky air f series iam sure AF is drain level means the same as A3 drip pan,pump,float switch,overflow ect ect
Paul
"KEEP IT COOL"
27-07-2006, 01:41 PM #3
Re: daikin AF fault
I think your right superswill. We had a problem a few years ago with a Daikin ducted system where the level sensor had got stuck. I´m 99% sure that gave a AF fault.
27-07-2006, 01:49 PM #4
Re: daikin AF fault
G'day Richard
AF= Malfunction of humidifier system
According to the info that I have.
(You probably knew that anyway)
As for the cause.I have no ideas.
Regards.
27-07-2006, 07:01 PM #5
Re: daikin AF fault
Im sure its a drain problem.Could be a few things such as water flowing back or clogged drian.
27-07-2006, 09:01 PM #6
Re: daikin AF fault
AF means that at thermostat off/condenstate pump off the float switch has made, so good chance that the drain is installed over its max limit and when the condensate pump goes off the water runs back in to the unit. Worth while checking that if the drain upstand is at its max height the pipe size should be reduced to 3/4 from 1" 1/4
A3 means the the float switch has made whilst the condensate pump is running. probably blocked drain! get the drip pan out and clean it!
Daikin fault codes
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
!!big Daikin Problem!! Codes,u4,pj, And E0
By airconengineer in forum Air ConditioningReplies: 21Last Post: 31-05-2007, 09:04 PM -
Chiller Fault
By iceman007 in forum Air ConditioningReplies: 2Last Post: 13-05-2006, 07:23 PM -
Daikin Indoor Unit
By ebo in forum Air ConditioningReplies: 10Last Post: 15-03-2006, 03:58 AM
