27-07-2006, 01:11 AM #1
Heat Load calculation for residential jobs
Hi guys:
Is there any software to make the heat load calculation for residential jobs, that you can recomend me?
Thanks.
Hernan
12-05-2008, 12:46 PM #2
Re: Heat Load calculation for residential jobs
some people here in sydney use 0.2Kw per sq/m, give or take.
Im after a program to do my heat load calcs for domestic and commercial.
12-05-2008, 11:50 PM #3
You guys are south of the boarder so no norther hemisphere programs will work for you. I use AC Calc by Clik (UK company who also do VRF selection software for manufacturers - Tosh, MHi etc). Might be worth checking with them so see if they do an upside down version!! Google Clik Software
Failing that you need to discuss with fellow souther hem affiliates.
Good luckIf in doubt read the instructions. If still in doubt follow them.
online heat load calculators
By pradyumna in forum Tools and CalculatorsReplies: 3Last Post: 07-09-2010, 06:42 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
oil in tank heat load calculation
By abbasi in forum FundamentalsReplies: 7Last Post: 13-06-2005, 08:36 AM -
Mortuary heat load
By smithgmp in forum CommercialReplies: 3Last Post: 05-05-2003, 04:43 PM -
Heat load calculation
By Tony in forum Technical DiscussionsReplies: 3Last Post: 29-07-2002, 06:34 PM
